Ashley Cook
- Nov 11, 2008
- 3
- 2
Hey Fiat Forum Members can you answer these ones
If so where is it situated on engine?
Is the water pump driven by the fan belt opposed to the timing belt?
Is the water pump situated front left bottomish of engine?
Is there a specific brake bleeding order? as i usually start the furthest away from the fluid container and then the next furthest until the last finishing the closest to the container in that order.
back driver side
back passenger side
front driver side
front passenger side, container side
Can a slack fan belt be tightened on this car?
Is replacement of the fan belt done just by undoing the alternater bolts?
Seven questions for people that know their stuff!!! CHEERS
1999 Fiat Seicento Suite
Does this car have a timing belt?
back driver side
back passenger side
front driver side
