Old 04-11-2008   #1
stalling wen cold and losing power past 4500 revs
orite iv had a litle trouble with my standard cinq sporting in the last few days. i 1st noticed it wen i started the car 1 day after work and it wouldnt idle, i hav to rev it slightly 2 keep it running, this problem disapears after about 10 minuits of running. the second problem is that wen im driving and i tek it past 4500 revs the car wont go any faster, it feels like a starvation of fuel or sumthin.has any1 else had this problem ir know wat could b causing it? many thanks "chris".
marron69 is offline Reply With Quote Quote
Old 04-11-2008   #2
Re: stalling wen cold and losing power past 4500 revs
Quote Originally Posted by marron69 View Post
oh and ino i shudnt do it but wen i take it 2 the limiter it bounces alot slower than usual. dno if thats any help. thanks again "chris"
Old 05-11-2008   #3
Trader Rating: 3
Firstly check the plugs out and also the HT leads, possibly renew them if they've not been changed in a while & also check the vac lines for blockages. If that throws up nothing try a compression test.
GoBe is offline Reply With Quote Quote
Old 05-11-2008   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
I think I understand the OP, these foreign language translator programmes do mangle the english a bit.
Check the manifold temp sensor.
PD
Old 05-11-2008   #5
ye i baught new spark plugs yesterday bt still not found time 2 change them lol. will defo fit them 2moro n let u no. thanks again "chris"
Old 05-11-2008   #6
kritip's Avatar
Trader Rating: 4
kritip has donated!
Are you dyslexic? Try adding a spellchecker to your browser.
kritip is offline Reply With Quote Quote
Old 06-11-2008   #7
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by kritip View Post
Remember this is an international forum. I think the OP is using a cheap/free translator from whatever his language is to english and its not very good.
PD
Old 06-11-2008   #8
Trader Rating: 5
fingers99 has donated!
Basta collo textspik!
fingers99 is offline Reply With Quote Quote
Old 06-11-2008   #9
Madmike has donated!
Ireland
Translated version below
Hello!
I have had a little trouble with my standard Cinquecento Sporting in the last few days. I first noticed it when I started the car one day after work and it would not idle.I have to rev it slightly to keep it running, and the problem disappears after about 10 minutes of running.
The second problem is that when I am driving and I take it past 4,500 rpm, the car will not go any faster. It feels like a fuel starvation problem or something.
Has anybody else had this problem or know what could be causing it?
Many Thanks.
Chris
Madmike is offline Reply With Quote Quote
Old 06-11-2008   #10
kritip's Avatar
Trader Rating: 4
kritip has donated!
Quote Originally Posted by rallycinq View Post
PD
No, he's British, so a spellchecker would hopefully improve the posts
Cheers Madmike
@marron69 - do you have any warning lights com on the dash. DOes the injector light come on when you turn the key in the ignition?
Old 06-11-2008   #11
Autotest Special
rallycinq's Avatar
Trader Rating: 1
I love the concept of the Irishman providing the translation, cheers.
I guessed it might be some young persons type of language, but the OP has not indicated a location, lazy sod.
PD
Old 06-11-2008   #12
oh sorry chaps, i failed to notice you were all properly spoken on here. no sir im not dislexic i just prosumed you would understand what I meant, after all they are only abbreviated words. anyway no the injector light does not come on apart from the few seconds wen i turn on the ignition. sorry for any txt speak earlier i will try my best not to do it anymore, its just habbits of an 18 year old. thanks for all your help "chris"
Old 06-11-2008   #13
Ireland
Something a bit bizarre about it alright!! LOL
(T) revs not going past 3.5k and judder kayl0rz Cinquecento / Seicento 43 04-03-2008 14:17
(G) Losing power! tashman Panda (Classic) 12 09-01-2008 22:34
(G) losing power obi1123 Punto (Mk2/2b) 6 30-10-2007 22:30
(T) Brava 1.6 stalling when cold and high revs idling Jure1985 Bravo / Brava 3 28-09-2007 09:38
(T) Brava 1.4 sx 1997 engine stalling when cold jo.ohan Bravo / Brava 0 05-05-2006 16:51
