Old 13-10-2008   #1
Shark Attack Champion
Clutch/Gearbox problem :(
Hi all
There has been vibration when i change gear for a while now, but now the problem is worse.
I am having difficulty selecting gears, first in particular puts up quite a fight, and the others arent easy until i get into 4th and 5th.
Can anyone help? Is it even the clutch that's the problem?
Lets list all the mods (no matter how small they may be) in our signature!
-Magic tree air freshener
-Carplan ice scraper
-Oh yeah i think i hoovered it the other day
-Bosch wipers
NaySei is offline Reply With Quote Quote
Old 13-10-2008   #2
Trader Rating: 5
fingers99 has donated!
Re: Clutch/Gearbox problem :(
Adjust the clutch first. Then come back.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 13-10-2008   #3
Quote Originally Posted by fingers99 View Post
ok
-Bosch wipers
Old 15-10-2008   #4
Quote Originally Posted by NaySei View Post
ok
Ya now its completely broken and its gone in the garage Clutch is in and wont come out
-Bosch wipers
Old 16-10-2008   #5
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
I take it the clutch pedal has gone to the floor, or has the arm jammed in the cover?
PD
Old 16-10-2008   #6
might be worth checking the release arm too (speaking from bad experiance)
little_yellow_beast is offline Reply With Quote Quote
Old 17-10-2008   #7
Stick your own title
mrcinquecento's Avatar
mrcinquecento has donated!
i would guess cable or pivots snapped. sounds from before like the clutch is wrecked anyway, and thats why the mechanisims gone, new clutch needed im afraid if it is
www.fiat-scotland.com,the home of all things both scottish and italian. it's a bit like having an irn bru with your pizza, only much tastier
98 Fiat Cinquecento Sporting 16v, 94 Land Rover Discovery 300tdi
mrcinquecento is offline Reply With Quote Quote
Old 17-10-2008   #8
If the clutch has gone to the floor after a while of sticking gearchanges, it could be that the cable has snapped ("L" shaped piece behind the metal cover in the passenger footwell).
As the "L" gets fatigued, it starts to crack and then the crack opens out when you push the clutch in. This affects the dis-engagement of the clutch so you have the gear-changing problem.
Eventually all the bending of the end of the "L" makes it snap off.. pedal goes to the floor.
Any sticky gear-change .. check the clutch is dis-engaging properly first.. and on the Cinq/Sei that could be caused by a failing cable.
18 for the cable from Fiat, so maybe less from a factor.
Ralf S.
No bullets for chaingun
Ralf S. is offline Reply With Quote Quote
Old 19-10-2008   #9
A new clutch, 3 days and 180 quid later its fixed
-Bosch wipers
Old 19-10-2008   #10
Trader Rating: 5
That's actually not bad for a garage job. People down south have been known to pay 300.
Old 19-10-2008   #11
Perhaps that's why the exact same thing has happened again then...Pillocks,
Back it goes
-Bosch wipers
Old 19-10-2008   #12
Trader Rating: 5
The cable snapped?
Old 19-10-2008   #13
The cable snapped?
I don't think it has.. i almost hope so however...
-Bosch wipers
Old 19-10-2008   #14
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Incorrect adjustment and the quadrant has fell off, is my guess.
PD
(T) Gearbox or Clutch problem?? Alastrina Punto (Mk2/2b) 1 14-09-2008 17:36
(G) Gearbox or clutch problem help please rema-d Bravo / Brava 8 04-02-2008 23:12
(T) clutch/gearbox problem??? Rog_50 Marea 5 16-02-2007 21:55
(G) Clutch problem? Gearbox... Sovereign Punto (Mk2/2b) 4 28-01-2007 15:22
(T) how do i know if its a clutch or gearbox problem? cinqichicken Cinquecento / Seicento 10 07-05-2005 18:18
