Erm... title pretty much sums it up really... I'm stumped! :bang:
cant you just follow the vacuum lines?
well you know where the map was on the SPI cento and the pipes that went to the TB.
should be similar on the mpi??
bear in mind ive never seen an mpi so im guessing here
infact post a pic up with no airfilter the next time you have the housing off and i'll add it to the engine type FAQs as i only have a stock photo![]()
on the spi its near the ECU pretty much straight above the brake servo/MS
Didn't me and Kris answer this a while back? On the MPI I'm pretty sure it's on the inlet manifold , R/H side looking from the front of the car, just to the right of the throttle quadrant thingy and slightly below it.
Yep, I told you that before
Its a combined MAP and air temperature combined into one unit
Kristian
Kristian
What do you mean, where do the wires go from the connector? THey run into the loom at teh rear of the engine, then directly to the ecu connector.
I have a pin out for the connector as well, but am off out now and not back till late. If you need the pin out i'll dig it out soon.
Kristian
