Hey all, I de badged my Multi and would like to reuse one of the badges at the front, but have no idea what to attach it with?????
What do people use please?
If you have a Hobbycraft nearby, they do a roll of double-sided foam tape that will do the job.
Make sure you get them straight!
If it is a dense foam, usually black or dark grey, it will probably be fine. If in doubt, you could test it on something that would not matter if it dropped off.
Ideally, badge, car and tape need to be warm! Many number plates have dropped off after being applied cold. (Usually about 7-10 days) Tape and badge in house works, but car would need warming. Park it with the sun on it, then add heat from a hairdryer until car is almost too hot to touch. Difficult this time of year unless you can get it into a garage. Don't use a hot air gun, it takes the paint off.
Might have to wait for the warmer weather. (3 days in June, 4 in August, don't miss them)
Car must be warm for the tape to stick.
