noname
I have a problem with my fiat brava 1.4 S 12V. To be exact I have an oil leak that is coming from front a bit under the valve lid where the dip stick holder is mounted to the block. I hoped it was only the valve lid gasket but after I took a closer look it pretty much seems to me there is a crack around the dip stick holder screw on the block. I am not sure what part of the engine it is. Should be the Cylinder head or the cylinder block, right? I am wondering how this problem could be solved. Does this part need to be changed or is there any other solution? Some kind of soldering or using a special glue. I live in Oxford, UK, so I am looking for a cheap car part shop across Oxfordshire or on the internet where I could buy the required parts. Used parts would also be fine I guess. I also am looking for a cheap and reliable garage that reapairs fiat cars. Does anyone know how much will it cost (approx.) for me separating the parts and the labour and what part(s) do I need to change / repair exactly if the above mentioned area is cracked?
Thanks in advance.
Thanks in advance.
