what usually happens is the cable's end pulls out of the handle because the cable is stuck. if you apply some WD40 to the cable to loosen it up it will prevent the problem recurring. often the cable can be simply reconnected to the handle, however if the handle has snapped where the cable conects you can get a handle from any scrapyard bravo brava or marea for less than the price of a pint.
