A simple test with the multimeter will give you the answer
See;
See;
Mine is firing on 3. Doesn't seem 2 b a spark on no. 3 cylinder. I've replaced spark plugs and switched them between cylinders, but it's still not firing on same one. I replaced the HT leads yesterday and no difference. Mine is a 1.4 bravo (yes I know) and so has 1 injector for all four pots so I kinda think that eliminates the possibility of a faulty injector? :bang:Is the coil the only option before an ECU? I ask simply because of the earlier post (quoted above).
Please help!!! (The fella I car share with for work is gettin a pissed with having to drive every shift!)
Thanks in advance, John
