Thread Tools
Old 13-12-2018   #1
Ireland
Brava 1.2 Diagnosing Wiper problems
Hi there. I have a Brava 1.2. I'm trying to narrow down a front wiper problem before I do much disassembly. What I found is that the Stalk pull (Wash and wipe), Stalk Toggle Up (Single Wipe) and the Stalk Down full (Fast Speed Wipe Continuous) don't work. What does work is the remaining functions on the Stalk, namely The Stalk 1 down (Flick Wipe) and the Stalk 2 down (Slow wipe continuous). It should be noted also that the Washer does work on the Stalk pull, just not the Wiper. And also should be noted that all the rear wiper functionality works.
Is this a Steering Column Multi switch problem or a problem with relays inside the motor/relay package for the front wipers??
Raptor88 is offline Reply With Quote Quote
Old 13-12-2018   #2
varesecrazy has donated!
Re: Brava 1.2 Diagnosing Wiper problems
Hi.
If all UP function wete 'dead'
I would blame the switch.. but it sounds like a mix..
Worth unclamping rake adjuster ..and moving the steering wheel. Column. And WIRING through a few arcs..
The wiring is tightly packed in there.
Only issue I had was loss of;
Self park
Intermittent wipe.
I fitted a ..scrapyard.. motor
Different manufacturer..from a different engined Fiat.
It worked perfectly.. weird..!
Charlie
Old 17-01-2019   #3
Ireland
Thanks mate. I'm thinking the same. Anyway todya I lost all wiper functionality *except* the pull (front wash, no wipe) and the twist and push (rear wipe and wash).
I think it's the relays given up the ghost. I'll have a closer look tomorrow.
EDIT: Just to add before I forgot. Yeah gave the wheel a shuffle around when it was loose. no joy there.
Old 17-01-2019   #4
COULD be the motor itself now.. Or its wiring
From what youve said.. it now does NOTHING
Old 11-02-2019   #5
Ireland
Just to get back to this. Found the problem. Stripped off the trim and all the stuff and found the connector just sitting there half in half out right on the motor/relay assembly. Dammit FIAT, make reliable connectors. Anyway pushed it right in, and secured it in with a good wrap of tape. Alls well. And just in time for the rain we had aswell.
Thread Tools
(T) Brava/Marea front wiper problems cgordon Bravo / Brava 14 02-12-2010 16:29
(T) Brava Wiper problems fbgirl Bravo / Brava 4 23-02-2009 22:20
(G) Wiper Problems Brava Charlotte Bravo / Brava 2 24-04-2008 21:00
(G) Fiat Brava Rear Wiper problems drsjp Bravo / Brava 2 13-11-2006 12:45
(T) Brava JTD wiper problems, and what models wipers will fit it? Mr Meltdown Bravo / Brava 0 14-01-2006 20:03
