| Thread Tools |
![]() | #76 | ||
Posts: 1,739 Thanks: 77 Trader Rating: 0 ![]() | Re: New Brava owner with a few questions I can't see my car right now but there would be some extra wires back from the hub if you have ABS. The basic SX model didn't have ABS (AFAIK), mine is the Formula edition with extra bells and whistles. If you have smallish rear drums then you have no ABS, mine has the larger ones that were probably the standard for the 1.6 upwards. My '95 Tipo has TINY discs and drums, but they work pretty well! May well be the same as the lower spec Bravas and Bravos....
![]() | #77 |
Posts: 397 Thanks: 28 Trader Rating: 0 ![]() | Re: New Brava owner with a few questions easiest way to see if you have ABS is to look under the bonnet at the round brake servo, the pipe from the master brake cylindrer will go to a box with 4 pipes and a couple of wires coming out if you have ABS, and there will be 5 pipes on the master cylinder if you do not, 1 from the brake fluid tank, and 4 directly to the wheels.
__________________ ![]() Marea Weekend 2002 Saint Moritz JTD 110 The thread Marea Weekend 1999 ELX TD100 (DECEASED head gasket failure) |
![]() | #78 |
Posts: 58 Thanks: 1 Trader Rating: 0 ![]() | Re: New Brava owner with a few questions Well, balls! I've been driving like an old lady, no abrupt acceleration, no banging on the brakes, short shifting when applicable, all that jazz. And all it got me was about 10-10.5l/100km. Which is, about a liter less than when I'm driving normally. Isn't this bad? I mean for god's sake, it's a 1.2! Granted, a pretty nippy 1.2 for its age but still, the car's had its maintenance, there's no extra weight on it, really careful/calm driving, it can't be drinking that much! What totally baffles me is that it consumes HALF that on the motorways! If I don't thrash it and keep a steady, leisurely pace at 90-120km/h, I can achieve 5.5-6l/100km easily! Gaaah!
__________________ Happiness is the road |
![]() | #79 | ||
Posts: 1,739 Thanks: 77 Trader Rating: 0 ![]() | Re: New Brava owner with a few questions Did you fully resolve your binding brakes issue? I mentioned that before as a possible cause of high fuel consumption. Cruising MPG you should expect to be quite impressive, it's a great shape for cutting through the air (especially with the boot spoiler!)/
![]() | #80 |
Posts: 58 Thanks: 1 Trader Rating: 0 ![]() | Re: New Brava owner with a few questions Yeah, the brakes are fine. Otherwise, I'd have been leaving behind a trail of flames and rubber a la ghost rider on that 500km roundtrip! ![]()
![]() | #81 |
Posts: 58 Thanks: 1 Trader Rating: 0 ![]() | Re: New Brava owner with a few questions Hey guys, some help needed. Can someone point out, with pictures, if possible, exactly all the engine mounts for the 1.2?
![]() | #82 | ||
Posts: 1,739 Thanks: 77 Trader Rating: 0 ![]() | Re: New Brava owner with a few questions Can‘t help at the Moment, but Mine with the Late Engine (2001) has an extra Mountin bracket from the cylinder Head top left to the inner Wing.
![]() | #83 |
Posts: 58 Thanks: 1 Trader Rating: 0 ![]() | Re: New Brava owner with a few questions Hey guys. Back again with a new update. It would seem that I haven't managed to avoid HG issues, myself. I'd noticed for the last few days the coolant going down during a drive and had to constantly top it off. I couldn't find any puddles or any leaks, apart from a little tear on one of the heater core hoses, which I fixed immediately. The problem, however, did not go away. I suspected some small tear somewhere else and scheduled a pressure test, although the car didn't get that far! One fine day, the car wouldn't start and I pretty much knew what was going on, although I had no other symptoms apart from a couple times it overheated for a very short while and I turned it off and topped it up. In any case, I removed the first plug and lo and behold, water (coolant). Tried to turn it on and... whoosh! Water in the cylinder, as well. At least the other three cylinders where dry, although there was water in the oil as well. Judging from the way it works (I didn't drive it of course, just started it) I don't think it's anything more serious than a head gasket issue. Here's hoping...
![]() | #84 | ||
Posts: 1,739 Thanks: 77 Trader Rating: 0 ![]() | Re: New Brava owner with a few questions Should be a straightforward repair since you didn't cook the engine, you may not even need a head skim. A refresh might inprove your performance / fuel consumption! ![]()
Thread Tools | |
![]() | Melonhead | Panda | 17 | 07-10-2016 23:28 |
![]() | Jim16v | 500 | 10 | 23-10-2009 20:26 |
![]() | Jules Sei | Cinquecento / Seicento | 9 | 22-05-2009 19:40 |
Questions from new Brava owner | Anonymous | FIAT Boo Archives | 8 | 22-03-2005 21:26 |
couple of questions to allan w (brava owner) | nick_wheelho | FIAT Boo Archives | 3 | 06-05-2003 19:52 |
