Thread Tools
Old 16-02-2015   #1
Hungary
Temp Gauge fixed
I just want to tell a story how i fixed my temp gauge and how i made unnecessary work on my dashboard! So last thursday I was driving my 1.6 SX when suddenly the temp gauge showed that my engine is about to blow, the needle was up in the sky. I stopped and popped the bonnet up, but the pipes were barely warm since i drove only 2-3 kms. After work I read the ecu and the temperature was just fine but the gauge showed the wrong temp. Okay i tought the dashboard is failing, it was a bit hectic, sometimes it jumped up and a slightly hit on top or a a bumpy road fixed it. I took apart the unit,(find horrible gluing job which was left by the prev. owner), bent the pins wich goes from the "motherboard" pcb to the gauge coils. Partly reassembled the unit and it was failing again. So i repeated the last prcoedure without any luck. I was about to order a used unit when suddenly i tought what if i disconnect the cable from the temp sensor . And voila the gauge went down to the bottom. (It was halfway with an ice cold engine). I want to stop here because you would ask why didnt i do this before i disassembled the whole dashboard. And my answer is: I was misguided by the ecu readings. And that's because i didnt check the datasheet of the sender unit, wich has two thermal resistors, one for the ecu and one for the gauge. So I replaced the temp sensor and it is working like it should Why am I writing this novel? I just want to tell you the moral of the story: always check part diagrams and datasheets! I hope you find it useful
Likes Adrian Bravo, franglais liked this post
bedofercni is offline Reply With Quote Quote
Thread Tools
(T) Pressure gauge Vs. Temp gauge Richyjon 500 (Classic) 9 13-01-2019 17:01
(G) Punto Trip computer reset, Issue with temp gauge/petrol gauge Hottwire Punto (Mk2/2b) 2 22-12-2011 22:42
(T) fiat brava 80 sx speedometer temp gauge petrol gauge not working but lights are on sunshine69 Bravo / Brava 3 23-08-2009 08:50
(T) Temp sender for temp gauge?? gaz12 Cinquecento / Seicento 5 17-02-2008 11:59
(T) Indicator, Fuel Gauge, Temp Gauge candleyes54 Uno 3 26-02-2006 19:57
