Old 25-12-2014   #1
Slow near side window going up and down
Hi there,
Does anyone know how to remedy the passenger window is very slow in going up and down. Its a 2001 1.2SX Bravo if that helps!
Any suggestions gratefully received
JonB
BT-slicksilver is offline Reply With Quote Quote
Old 26-12-2014   #2
Re: Slow near side window going up and down
Door card job off. Investigate for lubrication or faults to be remedied.
jimboy is offline Reply With Quote Quote
Old 26-12-2014   #3
Malta
same problem, remove all the internal parts from the door, got a replacement motor, lubed it all up and still the same problem, I just live with it at this point.
maniacbravo is offline Reply With Quote Quote
Old 26-12-2014   #4
Speedbump grimacer
Adrian Bravo's Avatar
Trader Rating: 1
Adrian Bravo has donated!
That's interesting I also have cleaned all the electrical contacts and lubricated the mechanical parts yet my passenger window is slow. Next time I have the door card off I will try an investigate more. I do plan on adding some soundproofing in the doors sometime soon.
Have you guys tried it without the door card on? I seemed to remember the top part of black trim on the door card was adding resistance to the glass.
Adrian Bravo is offline Reply With Quote Quote
Old 26-12-2014   #5
Finland
I've just ran PTFE spraylube to the parts where glass slides and its good for another year or two.
Maybe measure voltage at the motor when its running to see if you have bad connections somewhere?
Likes Peter Pick-Up liked this post
Neverth is offline Reply With Quote Quote
Old 27-12-2014   #6
Moderator
Peter Pick-Up has donated!
Russia
Quote Originally Posted by Neverth View Post
That's what I do as well with slow windows,cures it in most cases.
I use either silicon, or PTFE spray indeed.
Peter Pick-Up is offline Reply With Quote Quote
(G) Slow window winder renaultvation Punto (Mk1) 4 07-03-2010 02:44
Slow Window Alex80 FIAT Boo Archives 2 21-11-2007 13:44
Electric window switch drivers side window switch has busted the passenger side is working but the a Ricky FIAT Boo Archives 2 20-11-2007 19:57
(T) pass side elec window so slow going up sutty2tone Bravo / Brava 6 15-01-2006 12:52
Slow window, anyone help? Tom FIAT Boo Archives 4 04-01-2001 22:31
