TheCROW
Member
- Sep 19, 2005
- 466
- 98
Hey guys,
I have a fiat brava 99 1.6 litre 16 valves.
I have a problem:
Often when I don't wait for it to get fully warm, just after a couple of minutes wait (sometimes even when I start it and it's already warm after a drive), the acceleration is sluggish, even after it gets fully warm. This means that when I press the gas pedal, slow acceleration happens and the car doesn't react as usual and there's a delay between the gas pedal push and the lazy reaction of the engine. What's most weird about this is that when this happens and I turn off the engine and immediately turn it back on, the car will be back to normal..... Very weird.
I took it to a BOSCH service center and the guy plugged it in the computer (scanner), he accessed the error memory of the car and erased it because there were too many past errors, he told me to bring it in in a couple of days and then the error would be clear to him. But he told me that most probably I'll need to replace the oxygen sensor (will it fix the consumption?) because it appeared a bit slow during the test, and possibly I'll need to clean the injectors. (I don't think they need cleaning cos the car acts normally after the restart, what do you think?).
What do you think guys, need some help, could it really be the oxygen sensor causing these symptomes?
Thanxalot.
I have a problem:
Thanxalot.
