I've had the same problem, no one gave me a replay so i've decided to take the problem in my own hands, i've took the roof down, there you'll find the sunroof mechanism, you'll find that the sunroof has some clips that get bent and stick to a piece of gear mechanism so i recall, you'll have to bend the clips of the sunroof back down so that it doesn't make contact with other pieces, the biggest job is taking the sunroof down, you'll have to take down the front covers from pillars, handles that are up on the roof and other bits in the back, then slide the whole roof out trough the tailgate and position it on the roof of the car, if you have a friend helps you do this faster.
