im Axle Specialists
Old 02-07-2005   #1
Finland
rear fog lights are on all the time
Hello
Mystical electric problem:rear fog lights on Brava 1.6 sx-99 is on all the time.
When turning lights on the led on rear fog lights switch shines and the lights are on=rear lights are shining brightly.
Checked the connections on back-nothing.
Replaced the switch with another one but no luck.
Any ideas where to look next?
cheers
rike
rike is offline Reply With Quote Quote
Old 02-07-2005   #2
dave's Avatar
Trader Rating: 10
dave has donated!
Re: rear fog lights are on all the time
welcome to the forum
sorry i am crap at electrics. but if it was me i would take fog bulb out untill someone knows the fix.
THIS IS WHY TORIES CANT CLAIM HINDSIGHT! https://www.youtube.com/watch?v=bQDPQ8bz7cU
Old 02-07-2005   #3
Whaddya mean too old?
Deckchair5's Avatar
Deckchair5 has donated!
Well the fog lights are getting power from somewhere and the main suspect would be the switch. If there's a relay in the circuit then it could be jammed on other than that you have a short circuit somewhere. Take the switch out and try it. If they still light then your trouble is at the rear end from the relay (if you have one) to the light cluster. Wiring diagram I have here only shows a relay on front fogs
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline Reply With Quote Quote
Old 01-11-2006   #4
M8 u have put in a single point bulb in it need s to points other wise they will be doing two jobs like staying on...get a double conneter bulb...
dirty south is offline Reply With Quote Quote
Old 01-11-2006   #5
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
does it light up with all the other lights switch off?
if it doesnt then the power to the foglight is coming from a short to one of the other lighting circuits (usually sidelights)
if it stays on even when all other lights are switched off it may be a short to the ignition or a faulty switch (obviously not switch in your case) or a relay fault (there should be a relay somewhere)
although i'm with dave, just pull the bulb out till its sorted (need to do it before MOT). you can always stick it back in when its foggy.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
(T) Fog Lights bluestorm Bravo / Brava 35 01-02-2005 16:52
(T) Rear Brake Lights Jeffers Punto (Mk2/2b) 6 29-05-2004 23:58
(T) fog lights Azmondo Punto (Mk1) 7 20-03-2004 00:00
colour coded rear lights HP Leisure Lounge 1 08-05-2002 05:22
