Thread Tools
Old 16-01-2014   #1
Serbia
Steering wheel oil leak
A couple of days ago found that its hard to turn the steering wheel so I looked in the steering wheel oil reservoir and it was empty!
Bought oil and filled it up, checked under the car and could see it is leaking but could not locate it exactly.
It is under the reservoir, probably just at the steering wheel.
Can I fix this myself and what should I do, and how?
Zed McJack is offline Reply With Quote Quote
Old 16-01-2014   #2
Finland
Re: Steering wheel oil leak
If its low pressure side or return, yes (if it leaks when not running its most likely one of those, or loose clamp/broken reservoir).
If it is high pressure side/pump/rack depends on your skill and how small your hands are.
Drive it on ramp or something and look for the source, maybe unbolt the reservoir to check the clamps.
Different engines have the pump in different places so cant say anything about that.
Neverth is offline Reply With Quote Quote
Old 16-01-2014   #3
Serbia
Yes, it leaks without starting the engine.
The car is Brava 1.6 2001y.
Checked the reservoir it looks ok, nothing is leaking there, its somewhere 40cm below it but I cant see the exact place.
Thread Tools
(T) Seicento Oil leak & seperate Water Leak from Head?!?! Please help. Hamilton Cinquecento / Seicento 22 21-10-2010 12:45
(T) sports steering wheel insteed of original steering wheel vdhi Punto (Mk2/2b) 7 18-04-2006 13:12
(G) Power Steering Oil Leak krag Ulysse 2 23-12-2004 22:39
(T) 1996 55SX - oil (?) leak under both wheel arches LeakyPunto Punto (Mk1) 4 14-12-2004 13:08
