Bravo98paratrooperzimmer
155 HGT gutless till 3000rpm
hi guys injector light came on my bravo hgt a week ago, booked it in for a diagnostic and spent a day cleaning out the air intake all the way up to the inlet manifold,, ie throttle body and everything came out and got cleaned spotless,, now obviously having the battery reset the ECU and when fired up the injector light stayed off and doesnt show up now,, but its gutless till around 3000rpm and if you try and rev it from idle theres a huge flat spot thats actually embarasing so i try not to let anyone hear how bad it is,, ie pull away really slowly,,, under engine braking engine backfires massively,, dont mind it that much coz it sounds good but is this normal,,cheers for reading and any help would be a great push in the right direction as that southend on sea show is coming up and need to be there,, revs come down really slow too after u finally rev it hard whilst stationary,,, ps i cleaned everything with WD 40 and made sure it was dry cleaned before re assembly,, not running rich or anything as plugs are burning really well,,
