Old 22-08-2009   #1
could someone tell me my problem on 2000 bravo im guessing fuel pump
Hi
everyone ive got a bit of a problem with a buzzing sound coming from the rear of the car im guessing its the fuel pump it only started today when i turn key to put ignition on it starts buzzing for about 3 seconds then stops could it be a faulty fuel pump thanks
dmo123 is offline Reply With Quote Quote
Old 22-08-2009   #2
Here to help
bridges's Avatar
bridges has donated!
Re: could someone tell me my problem on 2000 bravo im guessing fuel pump
You should hear the pump. It is doing its job which is to, when activated, supply fuel up to the fuel rail on the engine.
If it is not constantly noisy then it should be fine. sometimes when there is a slight blockage in the tank it can cause the pump to work harder and become noisy however this is usually constant.
Ink Black Coupe,
Koni susp' kit, Strut/Subframe bars. Camber bolts, 3g Discs, Yellow pads. Ram air, S.I.P, FMIC, Superspool turbo, Aquamist, Full S/S decat exhaust. Hid's, Le kit and Tan leather.
Alfa 156 16v Jtd-m Ti 150bhp
http://i54.photobucket.com/albums/g1...2006/alfa1.jpg
bridges is offline Reply With Quote Quote
(T) Fuel pump problem ??? maisiemoo Cinquecento / Seicento 11 22-03-2012 20:10
(T) Fuel Pump problem panvanman Punto (Mk2/2b) 1 22-04-2008 19:41
(T) Mk2 fuel pump problem SSSekerko Punto (Mk2/2b) 1 12-09-2007 10:23
(T) 1.3 turbo i.e. fuel pump problem Mr. Twinkles Uno 6 27-07-2006 20:49
