steviebaby
infact if you remove the air box you can see wile it's running what the injector spraying looks like loads of pulses of fuel hitting the back of the throttle
maybe you could get it going faulty and have a look in there and see if it is indeed injecting should also here the injector there quite loud
if it is then maybe an air leak that only happens when hot due to expansion or something
OK - I may be on to something. Last weekend it was VERY cold but I decided I had to get out and give Betsie Brava one last try. It was my intention to check the voltage drop across the injector leads while it was in not-start-when-hot mode.
The engine started fine from cold (as always) and I warmed it up to normal operating temperature. I turned off the engine and it restarted straight away (as always). I then turned it off again and waited for the required 20 minutes to get it into not-start-when-hot mode. Sure enough, it turned over fine but did not fire once. While it was cranking (but not starting) I measured the voltage drop across the injector and it was within 0.2v from the measurement taken when it was stone cold. I then took out the injector, measured the resistance directly across the contacts and replaced it. I thought I’d try to start the engine and it fired up immediately. WOW! Normally the car has to stand for 1.5 to 2 hours before it will restart. I repeated the exercise – ran the engine, switched off, waited for 20 minutes, removed the injector, left the injector in the freezing cold. On replacing the injector the car again started immediately.
I have a theory: when cold the injector works fine. When hot the injector doesn’t work. Starting from cold the injector is cold of course, so works. When the engine is running the injector is cooled by the flow of cold fresh air over it and so keeps working. Turn off the engine and the flow of cold air stops; the injector begins to heat up from the heat rising from the hot engine. After 20 minutes it is hot enough to fail. Remove the injector into the cold air and it cools down. Replace it and the car immediately starts.
The next step is to replace the injector and see what happens. I’ve spent a small fortune on this Fiat and replaced so many parts it’s worth one last try. I’ll post the results.
