New to forum folks but have a big problem. I have a 2001 Bravo 1.6. While I was idle in traffic the other day the temp needle nearly went off the gauge. Limped home and checked the fan which was worked when I wired in 12v. I figure it is the thermostatic switch which is not turning the fan on. I want to replace it but am not sure what it looks like or where it is. From looking at the engine it looks like it is on a heater hose coming out the back of the engine block and is then connected to a blue hose running under the drivers side wing. Is this the thermostatis switch.....???
Thanks in advance..........
