Thread Tools
Old 05-10-2008   #1
arc
this is where i stand
arc has donated!
timing the 1242 16v without locked cams
hi all.
mate of mine has a brava and the timing belt has slipped. i dont know why yet - i've not looked at it, but it happened at low engine speed so as the cheapest and easiest solution am going to fit a new belt and then compression test the engine.
Last time i worked on one of these engines we just made sure that the bottom or top end just didnt move when the belt was off - but obiously now its all out of time.
Sooo what landmarks can i use to time it up?
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 05-10-2008   #2
arc
arc has donated!
Re: timing the 1242 16v without locked cams
nm, the engine is totally goosed. got spare?
Old 06-10-2008   #3
Trader Rating: 10
dave has donated!
was one on ebay for 100 quid the other day. always use the tools on this engine, because it has to be timed with all pistons in middle of stroke and cam pulley loose. you cant do it no other way with out it fcuking up
Old 06-10-2008   #4
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
Quote Originally Posted by arc View Post
1242 16v is an easy enough engine to come by. mk2 punto sporting or elx for example.
is it really buggered beyond repair? surely the worse case scenario is a few bent valves. go on, get your hands dirty
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 06-10-2008   #5
arc
arc has donated!
it has overheated, shredded the timing belt.. i'm not sure how. the inlet is full of emulsified oil / water mix. there is visible debris in the cylidners when viewed through the spark plug holes.
i'll get my hands dirty enough removing it and fitting a new 'en!
Old 07-10-2008   #6
arc
arc has donated!
well here are some pics, anyone take a guess at what went wrong to kill the engine cos i don't know.
It happened at low speed, approaching a junction, car stalled, PAS was lost (suggests bottom end was stationary to me)
Teeth stripped, that must've been the crank pulley?
Belt is only half width, and has a groove in the back of it
that groove matches the damage on edge of the tensioner;
looks like it had been rubbing on something, but there was nothing there for it to hit. i couldnt get the tensioner to go anywhere near close enough to the head.
inlet manifold was full of water / oil
as was the pipework from the airbox to TB.
All 8 inlet valves are bent;
had been driven for about 15mins before this happened and after the car stopped, it blew its coolant out the cap.
So what caused it, and what are the results of that. I can't work out which is which! (i know bent valves is cos the belt stripped, it didnt snap though)
Old 07-10-2008   #7
jug
jug's Avatar
Trader Rating: 1
jug has donated!
water entered a cylinder (or cylinders) locking the engine so quickly that the timing belt buckled and stipped, bending the valves. head gasket leaks are common on the 1.2 so i would assume that was the initial cause.
Old 07-10-2008   #8
arc
arc has donated!
what caused the damage to the tensioner though, it was metled as if catching something - the cam belt cover?
Old 07-10-2008   #9
jug
jug's Avatar
Trader Rating: 1
jug has donated!
the same force that killed the belt also pulled on every pulley on the belt just as hard. that can make the tensioner catch on the head. you can tell it caught on the head by the position of the wear (on the side of the wheel rather than on the belt running face).
check all the pulleys for signs of catching or any cracks or weakening where they are bolted on, or any sign that they are sitting off centre. timing belt is the weakest link but it can bugger other things before it lets go.
you have to imagine a cylinder full of water. the piston hits it and stops, jamming the crank pulley VERY quickly. all the other pulleys are still trying to go round and the parts they drive have a lot of momentum stored in their movement. the timing belt acts as the brake to stop them all very quickly, the force required to do that is huge!
Old 07-10-2008   #10
arc
arc has donated!
i understand the huge forces involved, but the tensioner is worn away rather than suddently impacted, it looks like it has been run next to a belt sander - and has a burr of melted plastic sticking up on it (that matches the damage on the belt)
the tesnioner has run out, if it has failed, hit the belt cover and then forced the belt off the waterpump puelly - could it take the slack long enough to keep the engine running,till it boiled the head and popped the gasket, hyrdolocking the engine? that would explain all the damage.
It def overheated as the coolant cap popped, and also all the HT leads were melted to the plugs (leads were new 12month ago if that). If the engine had died in one big bang then it wouldnt have had time, but it wouldnt have worn the tensioner down either
Old 07-10-2008   #11
Trader Rating: 10
dave has donated!
is the tensioner seized?
Old 07-10-2008   #12
arc
arc has donated!
no, its not - nothing is.
Old 07-10-2008   #13
jug
jug's Avatar
Trader Rating: 1
jug has donated!
when it slipped off the waterpump it would cut out within a few secs (timing is lost instantly)
yes i agree. in that case overheating was definately the initial problem that caused the head gasket leak. what caused the overheating? you need to find out.
is water pump pulley turning freely and without any play?
Old 07-10-2008   #14
arc
arc has donated!
it is turning freely now, but it may have jammed if there was fod in the cooling system.
hows about this for a sceneiro, car is running nicely - something hits the waterpump, yanks sharply on the cam belt, pulls the tensioner out of shape which then hits cam belt cover - shredding the outter edges of the belt car runs for a bit with clobbered water pump and begins overheating, whislt shredding the belt also on the now damaged cam belt tensioner, it gets halfway through and the waterpump jams again, stripping the teeth.
Gimme a few hours and il have the engine in bits and a chat with my mate about where the belt was and wasn't when the engine finally died.
Old 07-10-2008   #15
Ireland
Ahh - nothing like a good post mortem to keep the brain in gear
Faster Horses, Younger Women, Older Whiskey and More Money.
'01 Bravo JTD100, '98 Coupe 20VT
stylers is offline Reply With Quote Quote
Thread Tools
(T) 1242 / 1398 16v Head and Cams hot_fiat Punto (Mk2/2b) 6 29-08-2008 23:27
(T) Valve lift and Pocketed Pistons with fast cams on 1242 16v Pandasprint Punto (Mk2/2b) 5 05-02-2007 20:27
GSR 1242 16v Fast road Cams JamesMK2 Auction Watch 4 05-09-2006 21:52
