FIAT Auto Specialist Team
Old 02-08-2008   #1
Brooksy has donated!
oil and filter change
ok i'm doing an oil change and an oil filter change today so how do i do it? do i drain the oil then unscrew the filter?do i warm the engine up before i do it or not?any tip will be helpful
Brooksy is offline Reply With Quote Quote
Old 02-08-2008   #2
Trader Rating: 1
JoskeJTD has donated!
Re: oil and filter change
I would warm the car up for 5-10mins. Then leave it for another 5mins for it all to run down to the sump and cool down abit. Then i would undo the oil filler cap, undo the sump plug and drain the oil into a bucket or similar. Wait for it to all run out. Then either refit the sump plug and washer back, then remove the oil filter and drain that under the bucket. Then fit new oil filter, remember to smear a bit of oil around the rubber seal when you refit it. Then refill with oil.
Job done.
JoskeJTD is offline Reply With Quote Quote
Old 03-08-2008   #3
Get busy livin'
klemster's Avatar
klemster has donated!
Ireland
but why warm up the car before hand?
My Bravo
klemster is offline Reply With Quote Quote
Old 03-08-2008   #4
warm it up so the oil is less viscous and will drain out quicker and easier, i found that out yesterday
Old 03-08-2008   #5
Livefast123 has donated!
You should always warm the oil up first because it warms up all the gunk that is deposited around the engine and suspends it in the oil and comes out when you take the sump plug out. I always take the dipstick and oil filler cap off as this can cause a vacuum and not all oil will come out.
I'd also consider running a flush through the engine if this has never been done.
Livefast123 is offline Reply With Quote Quote
Old 04-08-2008   #6
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
i always add a can (or 2) of engine flsuh, then warm it up at high idle (2000rpm) for 15mins, with occasional blasts to higher rpm to increase oil pressure and remove the loosened gunk.
i also leave the sump plug out while i remove the oil filter because the act of turning it can cause it to leak dirty oil back into the sump.
a "kerb-it" recycling bin lid makes a handy drip tray if you dont have one.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
(G) oil filter change Chris-blk2000punto Punto (Mk2/2b) 9 14-09-2008 21:30
(T) Oil Filter Change gloop Grande Punto 2 23-03-2007 15:15
Oil and Filter Change topcat5 Lets Talk FIAT 4 12-02-2007 11:28
