I like the ride height i have just want stiffer springs and cant find them any where unless i go for lowering and with all the bloody speedy bumps we got it aint worth it is there any where i can jus buy normal spring bu just stiffer
you're looking at £25-35 for a pair from your local motorfactor. there are 5 sizes to choose from. you need to jack your car up and measure the gap between the 2 centre coils, front and back are different so measure both.
i think these are what i was looking at these are what i have come know as towing rubbers?? people use them when towing a caravan for example on back end ? also would bigger wheels help lift the car a little?
funny you mention these jug, i had been thinking about trying them on mine to make my -40mm springs a but harder and try reduce the body roll (esp at the back!)
yes they often get called towing rubbers and are used for towing caravans. bigger wheels will give you more clearance under the car unless you fit low profile tyres making the net effect almost zero. you can calculate the difference here: http://www.tyresave.co.uk/tyresize.html
