Thanks a lot for all the help and your time.
Stating the obvious (problem):
Lighter and Climate Control Fan motor (internal heating fan) is not working any more. It was working before and my mistake that a spring fell into lighter socket which caused it to short. From the manual (volume 2 page 243 - elec page 16) all I have found is that 20 Amp fuse in fuse box is needed to run this unit. I have also found that relay number (or fuse number) is 15 for this. I need to fix it and would like to know properly how should I fix/replace the fuse?
Is it possible to check if its the only thing to do to fix it?
How much it should cost and is it possible to fix it in less time?
Sunroof is kind of tempramental. On a rainy day I tried it and it opened but later on its not even moving slightly. I was thinking if there is a fuse for it as well. The interior light can be turned on or off but sunroof is not even moving. Dont want to spoil it as it might get a leak but as I know there is no leak at the moment so I should be able to get it open somehow.
What should I check and how can I fix this?
Sorry to take your time. Hopefully your reply will help others as well.
Many Thanks
Many Thanks
