The Brava brake light is made up of 8 (or 9 or 10 maybe?) 3w "wedge" bulbs. The bulbs need to be replaced as a strip (or replaced with difficulty). Will this fail the MOT if one or more is out and the light is still connected?
No:
Source:
http://www.motuk.co.uk/manual_130.htm
Secondly, if you don't want the risk and disconnect it, will it fail? No.
Hope that might help people in the future.
No:
Source:
High level stop lamps
These are lamps usually fitted in the rear window or boot spoiler of a vehicle and may consist of a number of light sources .
The lamp is one unit, so as long as at least one of the light sources illuminates when the brake pedal is pressed the lamp is deemed to be working.
Additional stop lamps
Any additional stop lamps fitted and connected must be tested. Where extra lamps are fitted and there is doubt as to whether they are connected, the benefit of this doubt should be given to the presenter
