im Axle Specialists
Old 09-06-2020   #1
Greece
Error p1305 neutral signal learn
PLEASE HELP....i have alfa romwo mito 1.4 170 hp and i have p1305 neutral signal error and check engine... I changed the clutch sensor and the transmission sensor and it still didn't go off...thanks a lot 😭
Liakaros is offline Reply With Quote Quote
Old 09-06-2020   #2
Re: Error p1305 neutral signal learn
You may need to us a diagnostic machine to turn it off
jackwhoo is offline Reply With Quote Quote
Old 09-06-2020   #3
Greece
I did it my friend....but nothing changed
Old 09-06-2020   #4
You may need to go through a setting process using a diagnostic machine.
Not just a code reader eraser.
Old 09-06-2020   #5
Greece
This happened the day I put a program on the car
Old 09-06-2020   #6
You may need to undo what you have done and put it back to how it was when it was built at factory
Old 4 Weeks Ago   #7
Is anyone still having this problem? I recently purchased a Fiat and am experiencing the same problem!
elvieryalex is offline Reply With Quote Quote
Old 3 Weeks Ago   #8
varesecrazy has donated!
Quote Originally Posted by elvieryalex View Post
What machine are you using..
Any other Codes being generated?
(T) P1300 P1305 no start stop and im pulling my hair out! jimmyk Punto Evo 3 04-06-2020 22:50
(T) Selespeed won't engage from neutral, no error codes. Maxxyr Stilo 15 22-05-2018 07:06
(T) Error Code 1688 2nd Idle learn (Phonic relearn) mb69rolls Idea 1 17-03-2016 17:24
(T) P0443 - EVAP Circuit Error (No signal) Stormwatch Stilo 6 04-05-2012 07:39
(T) MAF Sensor low signal error TangerineTractor Stilo 20 09-03-2012 13:25
