Hello,
As I know the T-jet 1368cc engines are the same fire engines with the N/a series engines like Punto 1.4 16v, Panda 1.4 16v 100 hp.
I am imaging that the N/A heads will have wilder camshafts with more overlap, and probably more duration and cam lift, especially the hot version of the 1.4 16v camshafts 95-100 hp or the older punto 16v mk1 1.2.
Does anyone tried those camshafts or knowing if are compatible with the t-jet heads?
Because with some searching someone could found those camshafts and are a lot cheaper as a second hand used parts vs new set of colombo barriani.
Thanks,
Alex
Thanks,
Alex
