FIAT Auto Specialist Team
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->How to clean/replace Fiat 500 1.2 MAP-sensor<!-- google_ad_section_end -->
Idling problems? High fuel consumption? etc..
Published by 500F
26-07-2015
Difficulty Level: 2
User Rated:Unrated
MAP-sensor measures the amount of air in a inlet manifold and also air temperature. The ecu needs these values to calculate correct fuel/air mixture.
Fiat 500 1.2 8v MY 2009 doesn't have MAF-sensor, only MAP-sensor I think.
Step 1. Disconnect battery negative terminal
Secure the disconnected negative terminal from any contact
Name:	battery negative.jpg
Step 2. Find the MAP-sensor
It's easy to access without removing the air cleaner. The MAP-sensor locates on the left side of inlet manifold.
Step 3. Use T25-torx tool
Undo the Torx-bolt and take care not to drop the torx-bolt on the floor
Step 4. Disconnect the wiring plug
Unclip the yellow clip and gently disconnect the wiring plug
Name:	map wiring.jpg
Step 5. Clean the MAP-sensor with specific cleaning product
Let the MAP-sensor dry complite
Name:	map cleaner.jpg
Step 6. Refitting is a reversal of removal
Option (Relearn the ecu if necessary)
Drive a long trip to relearn the ecu
We have very low outside temperatures in winter Finland. It may vary -0 celsius to -35 celcius. I was having a problem with my Fiat 500 1.2 8v engine idling. In cold days the idle speed varied a lot and the engine almoust shut down in every three seconds.
The problem doesn't exist during summer so I don't know that the problem is solved. The stock MAP-sensor was a little bit covered with water/oil and I think that waste will freeze in winter and that will cause problems. It would be the best way to renew the MAP-sensor and relearn the ecu but I started by cleaning it.
Likes BigCL liked this post
Old 26-07-2015   #1
Finland
Re: How to clean/replace Fiat 500 1.2 MAP-sensor
Read also my Fiat 500 blog!
http://www.500F.net/blog
500F is offline Reply With Quote Quote
Comment
Search this Guide:
(T) map sensor for fiat stilo johnathan19 Stilo 29 16-11-2014 10:07
Punto (Mk2/2b) Fiat Punto 1.2 Mk2 16v MAP Sensor (Used Once) krslynx Auction Watch 0 12-06-2011 14:13
(T) MAP sensor fault - but it isn't? [throttle body clean] Steely Stilo 21 01-05-2008 08:22
(T) can u clean a map sensor? johntra Bravo / Brava 20 13-02-2006 22:16
