FIAT Auto Specialist Team
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->1.2 8v disc and pad change<!-- google_ad_section_end -->
bit of an experimental video guide...
Published by Andy Monty
16-09-2012
Difficulty Level: 2
User Rated:
Difficulty Level: 1
Watch and learn
tools used
Jack
axle stand
wheel chocks..
socket set 1/2" drive.. and torque wrench
hammer (big and small)
pliers
small wire brush to clean calliper properly
brake cleaner
coppaslip
brake assembly grease (i used mintex cera tech)
small round punch
yes the windy gun compressor and such are optional it would have taken half an hour to film otherwise
more info here on regards cleaning calipers...
https://www.fiatforum.com/500/281466...solutions.html
which is a must read!
Old 16-09-2012   #1
Re: 1.2 8v disc and pad change
excellent video
thehytheman is offline Reply With Quote Quote
Old 16-09-2012   #2
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Agree
the video is good enough for most people to change a Punto - 500 - panda which all use the same brake setup With the minor change here and there
+1 there andy
One thing i dont advise is ABS people to push the fluid back in
Better to let it out via the bleed nipple
Reverse the fluid in large quantities can push crap into the ABS pump - and hello error light
Plus means you get fresh fluid in your caliper - less chance of boiling the brake fluid
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 17-09-2012   #3
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Fair point ziggy If the car is serviced as per requirement with a bi annual fluid change i would hope there would be very little FOD inside the fluid from internal brakedown of the rubber flexis
Massive gash
Just a little touch up
Old 18-09-2012   #4
Quote Originally Posted by Andy Monty View Post
Thats the problems with customers cars - you just cant tell
Knowing most of us on here have changed the fluid as a safety precaution - yea its okay to push the piston back in
It also depends if the bleed nipples come off....
ziggy
Meet Bumble-Bee
Old 18-09-2012   #5
Moderator
Andy Monty's Avatar
Quote Originally Posted by Ziggy122 View Post
ziggy
Ideally in one piece
keep my GP ones blathered in anti sieze compound knowing what vauxhall ones are like for shearing off....
Massive gash
Old 09-11-2012   #6
Thanks that's a useful "how to". Question: My wife has an 08 Fiat 500 Sport and the rear disks are corroded and will need changing soon. However, rather than a pair of 17mm hex bolts holding the callipers onto the hub they have what seem to be Alun Key bolts and I can't get them to budge (not helped by access to these bolts being impeded by the hub assembly). Has anyone tried doing rear disks on a 1.4 and do they have any advice? I'm thinking I may hacksaw the heads off the Alun Key bolts and replace with conventional M10s or whatever size they happen to be. Cheers!
Rich106Rallye is offline Reply With Quote Quote
Old 07-02-2013   #7
Quote Originally Posted by Rich106Rallye View Post
im having the same problem with the rear discs!! with the hub nut removed will the disc be able to be removed or is there an easy way of removing them? please help have the 500 on the drive with no wheels on one side atm!!!!!
peteys500sport is offline Reply With Quote Quote
Old 08-02-2013   #8
i have an answer now to the rear disc removal problem, the whole hub carrier has to be removed to access the 2 allen bolts at the rear its a bit of a job and recomended that you use an air gun to remove the 4 bolts as they will be really hard to remove and loads of brake cleaner to remove the grot off the threads, i will be finishing off tomorrow and will be putting a picture guide on here tomorrow as there is plenty of guides for the front and none for the rear on the 1.4 sport 500/panda!!!
Old 28-12-2013   #9
A belated thanks for the reply, Pete. I was looking again at our 500 Sport's rear brakes and came to the conclusion that the four bolts holding the hub in place would need to come off but couldn't get them to budge. Glad I'm not the only one who thinks this. But come on - what crap design by Fiat!
Old 20-07-2017   #10
Hey great tutorial. Just wanted to confirm if anyone knows if the same brake pads will fit the 0.9 TwinAir turbo 85BHP from early 2012? I have had a look online but there are a lot of models of pads for the 500. Ideally if someone can confirm the OEM or aftermarket part numbers from known brands like TRW, Bosch, ATE, Pagid, etc.
2019 Renault Megane RS Trophy 300 EDC
2020 VW T-Cross SEL
2012 Fiat 500 Twinair
2007 Renault Megane 2
GeoBog is offline Reply With Quote Quote
Old 08-02-2018   #11
chris3234 has donated!
Changed the discs and pads on my 09 diesel sport
Bit different to these caliper is held by two 12mm bolt's
And two 19 mm bolt's holding the frames to the wheel hub
Biggest problem I had was with the wheel locater stud's had one each side sized solid and snap when trying to remove them
chris3234 is offline Reply With Quote Quote
Comment
Search this Guide:
(T) 2005 Doblo MPV 1.3 disc and pad change al68 Doblo 3 27-09-2011 13:01
(T) HGT rear brakes, pad and disc change bozla Punto (Mk2/2b) 8 05-09-2011 21:23
(G) Disc and Brake Pad Wear?? Ophio Panda 11 14-10-2007 10:35
(T) Rear disc and pad change - 20v. :o/ HP Marea 9 13-07-2005 21:40
