Earlier this week we tried to go for an evening cruise in Martina, as we often do on the nice evenings. This time though, she wouldn't start. She tried, but wouldn't catch. Before that, she had been running perfectly since the rebuild (600km before) - more power, smoother running, good acceleration, etc...
Today I finally got around to troubleshooting her and came away utterly defeated.
First I pulled the fuel line to check the pump, as it was the most recent change. It pumped fine, so next was the ignition. Checked the static timing and wire continuity - all good. Next up were the spark plugs. Pulled the #2 plug and it looked a little fouled (see bottom-right pic), but nothing an Italian tune-up couldn't sort out, or so I thought (I was going to check the compression to make sure I wasn't getting too much blow-by). Pulled #1 and the Timesert insert came out with the plug (top pic). F@#k.
I cleaned and chased the threads and attempted to install a new insert. No luck. The threads in the head wouldn't grab and the insert would just spin and spin (threads in bottom-left pic).
So here I am, back to square one, and need to pull the whole motor apart and hope the machinist can install some bulletproof inserts in the messed-up threads I'm stuck with. If not, all that head work (intake valves, porting, surfacing) was for naught... and now I'm missing all the good driving weather. Days like this are really a kick in the teeth and make it hard to not walk away from this hobby.
