- Sep 6, 2019
- 25
- 8
Hi all,
I'd previously enquired on the HOT 704cc engine build thread about a problem I've encountered with my similar specification engine build. I had some very helpful replies, but I didn't want to completely hijack the thread with my own issues, so thought I'd start one afresh.
I'm building a 704cc engine based around a D'Angelo kit and 126 crankcase, but using some of my original 500L ancillaries and a Dellorto FZD carb. When it came to setting the up the valvetrain, Tom (The Hobbler) very kindly provided me with an article on correctly calculating the geometry of the rockers and therefore the necessary pushrod length. As a result, I know that I need my original 500 pushrods to be shortened by 2mm each (tip to tip). This doesn't sound like a lot, but it's enough that without doing so, there is no valve clearance and the whole setup is wrong/inefficient.
I've removed the tips from each of my pushrods (using heat and crowbars either side of each tip) and was expecting that to be the hard part of the exercise, before taking the rods to be machined at a local engineering shop. Having removed the tips however, it appears that the (aluminium?) pushrods have a very shallow hardened insert at each end, which would presumably also need to be removed before the rods themselves can be machined. I've attached some photos to illustrate what the rods and tips look like after doing so.
At this point I'm wondering what's the best approach to achieve the correct pushrod length- the insert at the end of each rod is only 1.5mm at each end and I can't see a way of removing this. I think my options are therefore as follows;
1. I could grind each insert down 1mm and then replace the pushrod tips, but this might compromise the integrity of the insert beneath each tip and after a bit of use the inserts could wear away completely and throw out all my clearances again.
2. I could obtain some chome-moly rod of close to the correct size/length, then have this machined down to the correct dimension for the tips to be refitted.
3. I could commission some custom pushrods, but can only find a company in the states who would do this.
Any advice or recommendations as to the best way forward?
