There was some discussion recently about distributors in my ultrasonic cleaner post and in particular about the springs on the bob weights as on the original 500 distributors the two springs had different ratings to give the right centrifugal advance characteristics. There is only one type of spring available now. I have 5 126 distributors totally stripped down at the moment, Zelmot and another maker, all made under licence fro Magneti Marelli. I got my micrometer on the springs and the wire gauge was the same on each pair.
Also I know from other distributors that the amount of mechanical advance is normally stamped onto the bob weight base plate. Most have 9 degrees but one Zelmot has 10 degrees 30 seconds On it. May be a coincidence but the spring wire was also 2-3 thou thicker. This amount of advance obviously pushed the design to the limit as the outer edge of the bob weights had rubbed very slightly on the inside of the distributor body.
