Fayray
Member
- Nov 6, 2017
- 286
- 92
I have just received my new 123 distributor and before I remove the old one I wanted to clarify a few things first.
1. There is a spacer and a small clamp in the box. My engine is a standard 499cc unit so I assume I'll be using the spacer? Will it become apparent how the clamp is used when I'm fitting it? The instructions don't even mention it.
2. The instructions say to connect the red wire to the +12v key-contact. So would the positive side of the coil be correct?
3. The factory set curve is 0. 1 has "idle control". Any suggestions on which I should use, or the differences?
It did come with instructions but they are brief and, for my simple mind, seem a bit vague. Everything I've read here suggests it's a very easy job but I just want to be more clear before starting.
