--------------How about using 100 octane fuel like shell v power racing?
Thomas
Hi Thomas,
I only suggested using a higher octane fuel to safeguard your engine until you have figured out what is the problem. 100 octane fuel should be fine for a short trial but shouldn't be normally necessary unless you're running a very high compression ratio. I mentioned Avgas because you work on aircraft - afaik, Avgas is available up to 115 octane :yum:
You later mentioned that you subsequently discovered that your valve clearances had closed up to almost nil. Was this before or after you had retorqued the cylinder head?
Tight valve clearances, as well as risking the burning of the valves and valve seats, also results in the valve heads running hotter , especially the exhaust valves (inlet valves are cooled by the air/fuel charge passing over them). This can cause pre-ignition.
Pre-ignition (as you probably know, but others here might not) is caused by something igniting the fuel air mixture before the spark plug fires.
Typical ways to prevent pre-ignition :-
Use a higher octane fuel or additives to raise the octane rating.
Reduce the temperature or pressure conditions inside the cylinder by :- retarding the ignition timing, making the mixture richer or reducing the compression ratio.
Use water injection or water/alcohol injection.
Decarbonise the engine if there is excessive carbon build-up.
Remove any sharp edges within the combustion chamber. - sharp edges can run hotter than surrounding metal and possibly ignite the incoming mixture.
You might find that setting the valve clearances to factory specs cures the pre-ignition
Regards,
AL.
