Greetings All, I have been enjoying my car of late - the rebuild went well and apart from a wiring gremlin to the starter all ok. So, I have chalked up 60km of steady running in and today thinks I will pop and get some fuel. Purring along and then a slight pop was heard and the engine stopped !!!
No clatter no banging no noise ( I know what that sounds like) To cut to the chase here I've isolated and proved the dizzy, plugs, HT leads, coil, capacitor and reset the timing the engine now runs and starts immediately, BUT only on one cylinder, the rear cylinder is not firing
I will say that the valve gear was getting noisy and noticed that the car had started to pink slightly ????? Having to wait for a cold engine will delay things, can the great and good on here confirm that it could be a valve or valves out of adjustment that's stopping the cylinder firing ???? I'm going to have a look inside the cylinder with my camera as well - just in case?????
Ian.
Ian.
