I am struggling to figure out how to install the clamp on wing mirrors. What am I meant to do with the 2 black plastic fittings? Which one is meant to be used where?
Hi and welcome, the mirror is designed to clip on to the A pilar,the small plastic plate goes between the mirror base and the outside face of the door pillar. The big spacer is for where it's needed. Don't tighten the screws too much otherwise you will damage the paintwork.
I bought 2 bullet clip on ones, and to be honest they are pretty abismal, the drivers side is ok but on the passenger side there is no way of putting it so you can use it as a mirror( maybe able to use it to hang my coat ).
