pepl4776
I had significant rust around my front suspension mounts cut out & new metal welded in during the aAugust. So had a 500 specialist shop do the work - remove front suspension, cut & weld in new metal, re-spray, reinstall suspension, redo alignment.
The shop owner dropped off the car at my home about 2 weeks ago, and I put it in the garage. I pulled out of the garage last night and NO BRAKES! (dead pedal). Thanks to low gearing and emergency brake I was able to get back inside safely.
I had no time to do a full diagnostic but a quick look under the hood and the reservoir was empty. Yet no obvious signs of dripping fluid on the garage floor.
I suspect that one of the front brake lines got a split/leak during the disassembly/reassembly steps. And the fluid slowly disappeared when the shop owner drove the car to my place for drop off.
So I plan to refill reservoir and have someone pump brakes until I find a drip. Any other advice or suggestions on how to track this down?
thanks
thanks
