FIAT Auto Specialist Team
Thread Tools
Old 23-07-2016   #1
Starter motor removal
Following the success of my washer pump replacement this afternoon I'm ready to tackle a bigger job
My starter motor doesn't bite every time so I'd like to refurb it myself.
What are the steps to remove and refit the motor and which tools are required.
BTW - I don't have a ramp so I'll have to do this through the engine bay.
tinyfiat is offline Reply With Quote Quote
Old 24-07-2016   #2
Re: Starter motor removal
Is it a 500 or 650 engine? Pull starter or solenoid?
If it's a 500 having a ramp won't make any difference as the starter is located at the top of the bell housing. If you do need more room underneath the car I used to jack the rear wheels up and put bits of wood underneath the rear tyres.
Disconnect battery. 3 bolts holding it on 13mm socket or spanner. Then it all depends on what type it is.
Damian
Paolo66 is offline Reply With Quote Quote
Old 24-07-2016   #3
I have a 500L with a pull type starter
Old 24-07-2016   #4
You will have to remove the fork for the pull starter which is held on with a pin fixed with a split pin. Disconnect the power lead held on with 13mm nut. It's a long time since I've done this so trying to do it from memory. Do you have access to a manual?
Old 24-07-2016   #5
Thanks Paolo66 - I have a manual but the instructions are very basic.
Before I attempt a removal, I need to find a replacement pinion/bendix as I think that's the part preventing a consistent bite when starting.
I'm struggling to locate the part for the 500L. Anyone know where I can get one?
Old 24-07-2016   #6
Yes try here
https://www.fiat500vdlaan.nl/en/webs...p?CategoryID=9
Only problem is you will pay the same again for postage. You can try ricambio.co.uk
I have a refurbished starter for sale if you get stuck
Old 28-07-2016   #7
Spain
Hi Paolo66 is spot on,it's as he said..
El cargador is offline Reply With Quote Quote
Thread Tools
(G) Starter motor removal tonyn Panda 6 27-05-2015 23:41
(T) starter motor removal andrew1620 Ulysse 1 24-11-2012 08:49
(T) Sporting Starter Motor Removal eamonnf Punto (Mk2/2b) 7 26-09-2012 13:43
(T) Any tips for Starter motor removal in Abarth volxstu Stilo 3 31-05-2011 18:35
(T) starter motor removal and refurb. christopher watson Fiorino (Mk1 / Mk2) 1 21-03-2006 18:58
