Technical Correct timing with 123
New York
Guys,
I have a 123 installed on my '70 500F. I'm reading through the threads here but I'm still confused. I want to time my engine with a strobe light to get it just right. Right now under load (like going up hill) I have a slight ping in the engine which is telling me my timing is off. How do I time it with a strobe light? What marks do I use to get it just right?
Regular unleaded but I add a lead substitute. Runs great but it's pinging a bit under load. I just want to be sure it's timed properly.
To retard the ignition rotate the body of the distributor in the same direction as the rotor is turning.
If as you look at it the rotor is turning clockwise, then if you rotate the body of the distributor in the same direction the rotor will make contact later in the cycle.
Chris
Wait... I don't have a distributor per se. I have a 123. How do I know which way it is turning?
This is my 123ignition setup.
If you have the 'wasted spark' type with no rotor or cap, the principle is still the same. To retard the ignition, the distributor body needs to be rotated in the same direction as that of the rotor or sensor which, in the case of the 500/126 engines, is clockwise as you look down on the top of the distributor.
Post a photo of your installation.
Chris
Chris
A slight turn clockwise worked! Thanks!
