http://www.athenaparts.com/files/pdfs/Big_Bore_FIAT_500_web_eng.pdf
Hello Gents
Can someone please comment on reason for the 2.5mm spacer plate between block and barrels?
When fitted now pistons at TDC sit below top of barrels by same amount , 2.5mm? All I can see this doing is reducing compression. Is it for valve clearance perhaps? At a loss if I need it or not. Appreciate all input in advance.
Hugh
Hello Gents
Hugh
