Afternoon all...
So after a good couple of months (and about 6,000km) of good running I'm having some difficulty with Gina. Previously starting would be very normal - ignition on, 'choke', and pull of the starter, and she would start immediately. After about 10-15 seconds I'd ease back on the 'choke', and then have it off completely after a minute or two. Running would be fine, and restarting when hot would be fine also.
A few weeks back I started getting some difficulty on the cold starts - taking a bit longer to start up and needing feather the accelerator a bit as well. This has gotten progressively worse; Yesterday and today I'm barely able to get her going without full choke, foot flat on the floor, and then I basically need to keep the revs up with the accelerator (or the manual throttle) for at least 5 minutes before she'll run on her own. Once I'm at that point she sounds like she's running a bit rough and occasionally she might peter out with a bit of a wheeze, or might not. When I give her a bit of gas on the accelerator there's almost a pause for a half second, until the power picks up; when letting it off she might go back to idle, or occasionally peter out.
Things done:
Yesterday I removed and blew out the jets. In the past few weeks I've renewed the fuel and air filters; based on past issues I changed out the capacitor too; the timing seems fine and I had it checked with one of the local guys; the tappets were adjusted about 4,000 km ago; and had new plugs about 7000km ago.
It has been really wet where we have been recently, so perhaps this is water in the fuel or carb? Could this be a fuel pump problem (though she seems to be pumping fuel fine, but with varying levels of fuel coming through the filter).
Any thoughts or suggestions appreciated!
Kieren
Things done:
Kieren
