Flemming,
Before you spend a small fortune on a twin choke carburettor (eg: Weber DCOE or Dell'Orto DHLA) consider that to get the best performance you will need a twin port head (eg: Panda 30). Fitting this head entails some minor engine work and significant panelbeating of the tinware. The carby will also need to be isolated from vibration to prevent fuel foaming and poor running.
If you are going to use a siamesed (2 -> 1) inlet manifold you should reconsider the twin throat route and buy a good single throat carburettor (eg: Dell'Orto FZD or an SU). The head needs no modification, the tinware fits and the inlet manifold is much simpler.
Dell'Orto FZD kits are available from Italy and listed on Italian eBay (
http://www.ebay.it/sch/i.html?_trksid=p2050601.m570.l1313&_nkw=dellorto+fzd&_sacat=0&_from=R40). They are not cheap (~450 euros for carby, manifold and air filter) but they are excellent carbies and once fitted and tuned they perform very well. You will get about the same performance from a twin throat carby but use heaps more fuel to do so.
The engine in my car is a 695 with raised compression, sports cam, big inlet valves, electronic ignition and a 32/28 FZD and it goes very, very well. I did a lot of research prior to parting with my hard earned cash and in general I found that those owners who had fitted DCOEs spent a lot of time getting them to run satisfactorily. Don't get me wrong, DCOEs are fantastic carbies and work brilliantly on engines set up for them (eg: twin cam Alfa motors) but are tricky to get right on our air-cooled twins.
Rebuild kits and tuning components (jets etc.) are available for the FZDs.
The first photo was an early trial fit and the second photo is the current installation.
Just my 2c,
Chris
