FIAT Auto Specialist Team
Old 19-02-2007   #1
electrical issues....fiat 124 spider
maybe someone can help...
I have a 1978 Fiat Spider 124... the lighting system that has "gone mad".
Symptoms:
the blinkers flash when the headlights are off, but both sides of the lights flash, even if i have the blinker like i'm turning left....
the blinkers do not flash AT ALL when the headlights are on...
the drivers side rear blinker light stays on when the lights are on...
passenger side rear parking light is not working (i'm american, driver is on the left).
what i've done to fix:
i changed the flasher for the blinkers. (maybe i bought the wrong one?)
i checked all the fuses; they're good.
i put brand new light bulbs in EVERY socket in the external system.
ALSO:
i found some blue oil filled thing underneath the dash; it had wires going into each end... it was loose (unscrewed), and oil was leaking.
i opened it up and there is a fuse looking thing with copper wire coiled around...the wire is broken. i think it's some sort of oil-filled fuse, but not sure. does anyone know what this is???
and any ideas why my light system is acting so weird?
ThinkQuickly is offline Reply With Quote Quote
Old 19-02-2007   #2
Re: electrical issues....fiat 124 spider
wait a tick, BLUE? was it shiney at all? and im not familiar with old fiats, but id suggest checking the harness and relay system.
[FONT="Comic Sans MS"][COLOR="DarkRed"]2003 Landrover Freelander S 2.0L Td4 :D [/COLOR][COLOR="Blue"]1989 Toyota Celica GT4 St165 Engine rebuild underway:rolleyes: [/COLOR] [COLOR="Red"]Fiatless once again :cry:[/COLOR] [/FONT]
Rampage94 is offline Reply With Quote Quote
Old 19-02-2007   #3
this mysterious device is blue plastic. green wires were plugged into each end. i unplugged them and brought it in the house.
it's about 3 inches long... it unscrews at the middle and inside is a thing that looks JUST like a fuse with copper wire wrapped around as the conduit. it's broken though (the wire), indicating to me that it's blown.
it's oily, and was partially unscrewed when i found it, so i'm guessing it was filled with oil.
Old 19-02-2007   #4
i have restored many a car and havent come across anything of your discrition, then again, i havent restored an italian, just old muscle cars and british roadsters. i'm sure the force will atract our fiat knights to your side, and they will set you straight.
Old 19-02-2007   #5
thank you sir, i'll hold for the fiat knights.
do you know whats up with my electrical system though? sounds like a bad ground or bad flasher..... confirm?
Old 19-06-2007   #6
USA
You need to clean all of the ground connectors well. After cleaning them, coat them with a dielectric grease to prevent corroison. Also, it would be a good idead to clean all electrical connetors and use dielectric grease on them as well. Fiat used copper wire but had aluminum connectors on the ends which becomes a great insulator when it corrodes.
90% of electrical problems in old Fiats are related to bad grounds.
GeorgeT is offline Reply With Quote Quote
Old 26-06-2007   #7
72FiatSpider has donated!
USA
I agree with George T. Grounds cause most of the electrical problems. Clean and coat with dielectric grease.
72FiatSpider is offline Reply With Quote Quote
(G) Benfield Motor Group Complaint about Fiat Stilo, 2002 respect Stilo 54 09-10-2006 20:15
FAO Bushboy Steven Leisure Lounge 13 25-07-2006 10:41
Soon New Fiat Owner: 1978 124 Spider ThinkQuickly Newbie Central 4 09-02-2006 04:58
