Thread Tools
Old 06-03-2019   #1
USA
Removing Spacer from Output Shaft
Is there a special tool or special way to remove the spacer without doing damage to it?
Thanks in Advance
ID:	198358   Click image for larger version
Karlton is offline Reply With Quote Quote
Old 06-03-2019   #2
Trader Rating: 1
portland_bill has donated!
Re: Removing Spacer from Output Shaft
Not seen that before, but it looks like it has been squeezed to fix it into position. If that is the case, it is not re-usable.
Need a workshop manual to describe how the new one gets squeezed, as will probably need quite a bit of pressure. @Pugglt Auld Jock have you seen this before?
13 years motor trade, 16 years motor industry. 14 years Driving Instructor & 7 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Old 07-03-2019   #3
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Quote Originally Posted by Karlton View Post
Thanks in Advance
The workshop manual and the parts catalogue show the cross grooved spacer held on with a circlip, so the spacer should just pull off by hand. The manual doesn't specify any special tool required to pull it off.
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 07-03-2019   #4
USA
Yes, and so I tried. The circlip came off easily but the spacer wouldn't budge .. not even with a gentle hammer tap. Today I'll try a little bit more force.
Old 07-03-2019   #5
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Bearing puller might be your answer.
D
Old 08-03-2019   #6
USA
Thanks to all! A puller seemed to do the trick, although it was a little large and I may need to replace the spring
Thanks to all for the help!
ID:	198508   Click image for larger version
Likes Pugglt Auld Jock liked this post
Old 08-03-2019   #7
Pugglt Auld Jock has donated!
Nope. Believe it or not, I've not yet had to take any of our Fiat gearboxes to pieces. In fact it's been about 15 years since I did anything more than seals and linkages on any box! Lucky me!
Pugglt Auld Jock is offline Reply With Quote Quote
Old 10-03-2019   #8
Hi Karlton. Glad to see you solved the problem and I congratulate you on tackling this job - brave man! I'm not at all familiar with your model (where Fiats are concerned it's mostly FWD Pandas and Puntos for me - although I did help a friend who owned a 131 Mirafiore and another who had a classic rear engined 500). A lot of the older cars I used to work on for a living - Morris, Austin, Hillman, Vauxhall, etc, etc with rear wheel drive had gearboxes very similar in concept to this from what I can see in your images. They pretty much all had prop shafts with metal universal joints not the donut your's has. Although my Imps had them on the driveshafts to the wheels as did the FWD Triumph 1300 (not a good idea - too much torque used to destroy them quite regularly). I'm struggling to understand why you have that spacer and rubber on the shaft at all - what does it do? why is it there? does it engage with a "socket" on the driven shaft?
I'm consumed with curiosity!
regards
Jock
Thread Tools
(T) Reconditioned gearbox output shaft trilix Panda 4 25-08-2013 20:05
(T) G/Box Output Shaft Seal Replacement, 1.6 richydraper Stilo 17 19-05-2013 19:26
(T) Info: Diff shaft output specification kritip Cinquecento / Seicento 5 15-01-2009 12:53
(T) Punto Mk1 - Differential Output Shaft Oil Leak BryanT Punto (Mk1) 3 04-12-2007 21:07
