Old 08-10-2008   #1
Starter issue
Well here it is almost a year later and i am still in the process of getting this 79 Fiat on the road. I ran into this deal last year and started redoing alot of it but it had set for many years. The brakes are all done and i did get it running. This is where the question comes in. I was driving it and it died, I killed it when shifting, and it was totally dead no starter click or nothing. battery was good lights and accessories all worked, so i push started it and it ran. My thoughts were the starter, wrestled it out and bench tested it, it tested out ok. So i put it all back together and nothing, but i still can push start it. Any ideas for me to check??? Still kinda new to the Fiat world. Thanks for the help. I attached a picture of the shape I found it in before i started on it.Click image for larger version
Aaron R is offline Reply With Quote Quote
Old 08-10-2008   #2
42 Wallaby Way Sydney
bludvl_x19's Avatar
bludvl_x19 has donated!
Australia
Re: Starter issue
Hi Adrian, I had a similar problem with my X1-9, it turned out to be a faulty connection from the power to the starter soleinoid, which was easily fixed.
I do hope that helps you.
Michael
Try not to become a man of success but rather try to become a man of value. ~Albert Einstein
bludvl_x19 is offline Reply With Quote Quote
Old 08-10-2008   #3
Re: Starter issue
I used a voltage tester and it seems as if I am getting the same amount of power to the starter as what the battery is putting out.
non starter kermit Lets Talk FIAT 3 24-06-2008 13:14
(T) starter! mjurma2 Tipo (Classic) 0 25-12-2007 22:58
(G) non starter neil-r Ulysse 1 06-12-2007 00:20
(G) non starter ek247 Punto (Mk2/2b) 3 05-09-2007 20:39
(T) Non starter bazza660 Doblo 0 13-03-2007 21:31
