noticed last night on my way home that my temperature guage was quite high and the radiator fan was continuously on.
I turned the heating up to full hoping to take a bit from the engine but it just blows cold. Luckily I don't live far so got home before it overheated.
Had to get a lift in this morning but will try and diagnose tonight when I get in.
The only thing I can think off is occasionally I have noticed a gurgling sound like there is trapped air in the system. It has been doing this for 6 months or so since I changed the thermostat at Xmas.
The car does not use any water, does not seem to have any water in oil and starts/runs fine.
I'm hoping that there is just and air lock in the system somewhere so when I get home I will :
any idea's on how I could test the water pump ?
and can you think of anything that I have missed ?
any advice much appreciated
- remove bottom radiator hose and drain water.
- open radiator vent and heater vent screws.
- top water back up till water comes out of radiator screw and then heater vent screw - tightening them as I go
- put expansion cap back on and start engine with heater on full fan and heat.
