kawasakikz1
Just picked up my mother's 2016 panda. It had a new battery last week. The BlueMe USB are dead and the odometer meter is flashing. I've refitted the battery to no effect. Any suggestions would be helpful. Many thanks
Blue and me (B&M) module almost certainly dead. Module is under the (RHD) driver's seat - it needs to be unplugged here since it tends to fail "on" leaving a parasitic drain on the battery when parked (flat battery within a week if car not used).Okay thanks. For help
Sir, what do you mean try the battery can u please elaborate,As mentioned try the battery first, but blue and me is very sensitive to voltage spikes so it maybe dead and need repaired.
Disconnect the battery for 30 minutes to allow the system to reset. If it still doesn't work the blue and me is dead and needs repaired/ replaced or removed.Sir, what do you mean try the battery can u please elaborate,
i just already doing disconectting the batery around 1 hour, and plugin in buat still flashing,Disconnect the battery for 30 minutes to allow the system to reset. If it still doesn't work the blue and me is dead and needs repaired/ replaced or removed.
can u give advice what shoul i do next sir?
It'is mean i can't doit by my self sir?Hello,
That BASIC RESET, obviously was not enough
You need to unplug the B+M(as it is the root of your problem)
Then do a System reset
You need Software for that
the worst think is fiat has no authorize service center in my country (Indonesia)
