Hi JrkitchingThat doesn't look like the factory fit wheel from a 2009 Active; I'm thinking someone has replaced the wheels at some point in its life.
OEM wheels would have been 13" steel running 155/80x13 tyres, with full size 13" plastic trims secured by the wheel bolts, like this one.
Looks like a FIAT wheel, though - anyone recognise what it's from?
They are definitely not the original wheels, so there's no point searching for 2009 Active Eco wheel trims.This is a photo of what the three other wheels look like
Correct; these were needed to make the 119g/km CO2 cutoff with the Euro4 engine.Think that they had 13s with ecocontact tyres.
Any help to find something that covers the wheel centre would be much appreciatedPretty sure they are Punto 14" wheels.
Active ECO didn't have alloys. Don't think any of the ECOs did. Think that they had 13s with ecocontact tyres.
This is close, but it's not the same. It may, or may not, fit - so make sure you can return it if it doesn't. You might be able to find the same thing from a breaker in the UK, for (hopefuly a lot) less money.Any help to find something that covers the wheel centre would be much appreciated
Brilliant, Thank you for your help, it is much appreciated.This is close, but it's not the same. It may, or may not, fit - so make sure you can return it if it doesn't
Just type the part number into googleHi
If you could advise on alternative wheel trims to the original ones, it would be much appreciated.
Hi
Yep.Mk2 punto ELX trim
Look at my 2004 panda.. That was on punto alloys
Or maybe the marea weekend
Tricky bit.. All older Fiat have Blue centre badge..
Red is @2008.and on
That's how hard it was to find a picture showing the OP's centre cap, albeit with a blue centre. I'd expect that, by now, finding a secondhand one is likely to be the only option.Thanks for the Hungarian links
Or this maybe.Hello and welcome to the forum
That doesn't look like the factory fit wheel from a 2009 Active Eco; I'm thinking someone has replaced the wheels at some point in its life.
Looks like a FIAT wheel, though - anyone recognise what it's from? The later 1.2 mylife 169's had something similar, but not quite the same - like the one below.
A picture of the complete wheel & tyre might help.
That's Dynamic IIRC..Or this maybe.
