Nicabockaglory
- Jan 18, 2016
- 15
- 2
Hi All!
I'm new to this site so still trying to get used to it. (bare with me)
My Fiat punto 1.2 8v X reg will not start. (Does turn over but just not starting)
I've had it for about two years.
A few months ago occasionally I kept having a clicking sound coming from my steering wheel column. The car still drove fine with absolutely no issues. It wasn't all the time either. (would come and go)
Then a while ago (couple months back) I went out to start my car but it wouldn't start & petrol light was flashing saying no fuel in the car which was incorrect as at least half a tank full.
Anyway the next day car started and it was fine.
It was fine a good while after that then a few weeks later the same problem where it wouldn't start say the Monday but would be fine on starting a little while later or on the Tuesday.
Up until a short time ago the non- starting issue became a lot more frequent. Like days in a row it wouldn't start at all and also there were now 3 red warning lights on the dashboard that wouldn't go out (not there before. Red power steering light, red low engine pressure oil light & red fuel injection system failure light) aswell as the petrol gauge reading empty & the petrol light flashing. When it got to this point the car just eventually wouldn't start at all.
I had my uncle check for bad connections, blown fuses...etc still no luck in starting the car or finding out what the problem was.
Anyway all the constant trying of starting the car eventually made the battery go flat.
My unc then disconnected the battery charged it for a day then put it back the next day and the car started.
Went & started it the next day it started. Then the day after not starting at all and same 3 red warning lights & petrol light flashing.
This is when I called a mobile mechanic out (sunday gone) he couldn't start the car either. He checked for electrical faults none came up he also changed the crank sensor & still nothing. I believe he did check fuel relay/ pump too but nothing. Which he found strange as the petrol constantly flashes & gauge registers the tank as empty.
When I explained about the clicking in my steering column a few months back he believes that my key may be faulty & I need a new one to be reprogrammed to start the car. Thing is that procedure isn't cheap & I'm worried that's not the problem. I don't have a key code either to even test his theory as he isn't even 100% sure himself.
I'm hoping someone can help or has had similar issues. I'm at the end of my tether with this. Frustratingly I saw somebody on another forum with the EXACT/IDENTICAL same symptoms as me but it was a 2012 post, so I don't think I'll be able to make contact with them. So frustrating
I'm so sorry for the book I've just written but I'd rather explain the full story, so anyone helping can get a clear idea of what's been happening.
Thanks.
Thanks.
