Technical Punto 2004 1.2 8V missfire/failure
rkwheeldon
Missfire started a week ago with intermittent engine warning light. Took it to my mechanic who read error codes which indicated missfire on No. 4 cylinder. Replaced all plugs and new leads. Missfire returned and now continuous with engine management light on all the time. Also mpg reading stopped if thats a clue. Tried to start yesterday and it wouldnt. Any help much appreciated.
Basics :
Has the coolant level dropped?
What does the oil look like on the dipstick?
Yellow warning light..? 🤔
That's good news.. As should rule out head gasket 🙂
So..
The garage visit restored service for a little while.. (so something they did was of benefit..)
The Yellow light is generally just a check on emissions (a sensor in the exhaust)
A misfire means it doesn't burn all the fuel.. And the sensor warns you of that
Common 'ish to have a Coil Pack fail on the 8 valve FIRE motors
There are 2, serving 2 cylinders each
When previous light was on, did it tick over smoothly.. Or lumpy?
Intermittent smooth/lumpy. The new leads and plugs hasnt made a noticable difference. My guess is coils next but for the car not to start at all? I would have expected start but missing so no start has me wondering. Also does the lack of mpg info indicate a problem with the ECU?
Realistically you want to ask the garage why that work made no improvement..
They should have ruled out a failing coil pack before your @£100 bill
Does the car make any attempt to start?
I remember how gutless my sons 1.1 was when a coil pck failed..
But it DID RUN..!
Coil pack had failed. Engine now starts but runs rough. Diagnostics say injector failure on cylinder 4.
So, 4 injectors ordered!
